arunis Paskelbta Kovo 1, 2015 Pranešti Dalintis Paskelbta Kovo 1, 2015 Normaliai čia viskas, deutz,as sutvarkė šitą problemą, stabdžiai smarkoki buvo priekiniai tai kad jis net normaliai stabdyt dar nebuvo pradejes o vat cia tai stabdo (panasiai nuo 1:30) Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
manttys Paskelbta Kovo 1, 2015 Pranešti Dalintis Paskelbta Kovo 1, 2015 Domejausi ttv serija, kaina nebloga pagak tai, ka gauni ir uzmatau toki dalyka Cia normalu skaitosi ? DF paaiškininmas: On the 14th April 2013 a 7250 TTV was provided to the ADAC Institute in Haltern am See,Germany, to undertake a series of routine brake tests under various working conditions.During the brake test, in transport conditions with the front axle suspension active, the axlesuffered a significant failure under heavy braking. The failure in question has appeared on various social media sites, which in turn causedeven greater concern. Obviously failures of this nature are investigated as a matter ofurgency, and with that, we can confirm the cause of the failure has been identified andresolved. Thorough checks of the mechanical components and controlling software for the front axlesuspension revealed a problem with the software parameters on this particular machine.Under heavy braking conditions the software is designed to stop the full stroke of the frontaxle suspension in order to obtain maximum braking efficiency. On this occasion thecalibration of the parameters was not completed and the rams extended to their full capacitychanging the geometry of the axle beyond the normal operating limits. We can confirm all machines in service have been checked without any similar problems,however, all units have been re-programmed as a precautionary measure, and can thereforeresume in normal service. We would like to stress this has been an isolated case and in noway cause any on-going concern with the Series 7 range. Kas nemoka anliškai, tai trumpai: nebuvo iki galo sutvarkyta programinė įranga, ko pasekoje priekinės amortizacijos cilindrai ne susitraukė, o kaip tik išsistūmė iki galo stabdant. O žiūriu versijų tai n atsiranda iškart Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
jevgenijus Paskelbta Kovo 1, 2015 Pranešti Dalintis Paskelbta Kovo 1, 2015 Nezinau...kaimynas butent toki turi, laksto kaip akis isdeges ir visdar su priekiniu tiltu. Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
greitail Paskelbta Kovo 1, 2015 Pranešti Dalintis Paskelbta Kovo 1, 2015 nezinau as tai po tokios reklamos i tos serijos traktoriu puse ne neziureciau ir raso kad programiskai tik patobulino . cia akivaizdziai gelezi reikia tobulint juk pasitaiko ir i duobe stabdant ratu ilekt, tada jokia programa negelbes jai gelezis per silpna Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
jevgenijus Paskelbta Kovo 1, 2015 Pranešti Dalintis Paskelbta Kovo 1, 2015 nezinau as tai po tokios reklamos i tos serijos traktoriu puse ne neziureciau ir raso kad programiskai tik patobulino . cia akivaizdziai gelezi reikia tobulint juk pasitaiko ir i duobe stabdant ratu ilekt, tada jokia programa negelbes jai gelezis per silpna Na tada, nepirk ir JD nes man asmeniskai kaip ir uzkale variklis, o bebunant servise atvare nauja S serijos kombaina irgi uzkalusia sirdimi. Panasiu pavyzdziu apie visas markes pilna, tiek kad sitas video labai jau vaizdus, ispudingas...ir visgi tai yra isimtis, o ne taisykle. Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
eimas07 Paskelbta Kovo 8, 2015 Pranešti Dalintis Paskelbta Kovo 8, 2015 tai vienintelis turbūt toks atvejis, kas čia žino brokas ar kas buvo, aš kol tikėjausi gauti paramą galvojau tik apie df, dabar visi planai keičiasi taip kad apie nieką nėra prasmės galvoti prie tokių pieno kainų. o tai ka pasiemei ir del ko persigalvojai ? pakolkas su DF sulo geriausia komplektacijos ir kainos santyki. uz DF 5105.4 G DT MD GS. nori 129 tukst. litais, gal kas kazka girdejot apie 5 serijos G modelius? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
remis30 Paskelbta Kovo 8, 2015 Pranešti Dalintis Paskelbta Kovo 8, 2015 o tai ka pasiemei ir del ko persigalvojai ? pakolkas su DF sulo geriausia komplektacijos ir kainos santyki. uz DF 5105.4 G DT MD GS. nori 129 tukst. litais, gal kas kazka girdejot apie 5 serijos G modelius? seip nh ar case tokio tipo pigiau Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
eimas07 Paskelbta Kovo 8, 2015 Pranešti Dalintis Paskelbta Kovo 8, 2015 Gal ir pigiau, bet jie tušti būna, o čia padori komplektacija ir plius oras į tą pačią kainą įeina. Pvz už NH TD5.115 prašo 115k lt ir pustuštis. Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
remis30 Paskelbta Kovo 8, 2015 Pranešti Dalintis Paskelbta Kovo 8, 2015 Gal ir pigiau, bet jie tušti būna, o čia padori komplektacija ir plius oras į tą pačią kainą įeina. Pvz už NH TD5.115 prašo 115k lt ir pustuštis. paziurek t5 serijos ten rimtesnis ir slaunys kelia daugiau ir kaina panasi Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
eimas07 Paskelbta Kovo 9, 2015 Pranešti Dalintis Paskelbta Kovo 9, 2015 tai kad padorus t5 šimtinukas kaštuoja netoli 40k euru. O DF siūlo geresni variantą, tai kame čia bairis ? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
tautex1 Paskelbta Kovo 31, 2015 Pranešti Dalintis Paskelbta Kovo 31, 2015 sveiki norejau paklausti gal yra dirbanciu su 6140 modeliu kokie apie juos atsiliepimai ? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
adblue Paskelbta Kovo 31, 2015 Pranešti Dalintis Paskelbta Kovo 31, 2015 Su TTV deže galvoji? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
eimas07 Paskelbta Kovo 31, 2015 Pranešti Dalintis Paskelbta Kovo 31, 2015 Gal kas turit kokios informacijos apie DF 105.4G ? Jie eina su SDF FARMotion varikliais, gal kažka apie juos esat girdėją? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
tautex1 Paskelbta Kovo 31, 2015 Pranešti Dalintis Paskelbta Kovo 31, 2015 ne TTV paprastesne nes su ta deze kaina padideja gerokai Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
saramedlov Paskelbta Balandžio 2, 2015 Pranešti Dalintis Paskelbta Balandžio 2, 2015 O mane sudomino šis modelis Deutz fahr 6160 ttv. Vadyba sakė, kad yra du parduoti į Marijampolės ir Kazlų rūdos rajonus. Gal kas žinote daugiau apie šiuos modelius ar bent ūkius kur jie dirba. Nes pagal kainas ir komplektacijas (bent jau Ką pasėsi parodoje kalbėjau su visais įmanomais konkurentais ) tik NH 6 165 yra pigiau. Bet tai NH.... Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
viktorass Paskelbta Balandžio 2, 2015 Pranešti Dalintis Paskelbta Balandžio 2, 2015 O mane sudomino šis modelis Deutz fahr 6160 ttv. Vadyba sakė, kad yra du parduoti į Marijampolės ir Kazlų rūdos rajonus. Gal kas žinote daugiau apie šiuos modelius ar bent ūkius kur jie dirba. Nes pagal kainas ir komplektacijas (bent jau Ką pasėsi parodoje kalbėjau su visais įmanomais konkurentais ) tik NH 6 165 yra pigiau. Bet tai NH.... O kas blogai su NH? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
ggg Paskelbta Balandžio 2, 2015 Pranešti Dalintis Paskelbta Balandžio 2, 2015 investuojat i daikta, kuris uzdirba pinigus ir kazkaip pirmas kriterijus yra kaina. Tai SAME dar pigiau.. Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
vyttas Paskelbta Balandžio 2, 2015 Pranešti Dalintis Paskelbta Balandžio 2, 2015 investuojat i daikta, kuris uzdirba pinigus ir kazkaip pirmas kriterijus yra kaina. Tai SAME dar pigiau.. O tu manai, jog DF prastas pasirinkimas? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
unia Paskelbta Balandžio 3, 2015 Pranešti Dalintis Paskelbta Balandžio 3, 2015 Tas vienas ir yra pas mane bet pradirbęs tik 200 moto ,dėl pasirinkimo esu patenkintas 100%,o kas bus ateitį ,manau nė dėl vienos markės nieks neužtikrintas. Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
deras Paskelbta Balandžio 3, 2015 Pranešti Dalintis Paskelbta Balandžio 3, 2015 O kas patinka/nepatinka per tas pirmas moto valandas, domina, nes pats žiūrinėju. Iš kokių dar variantų rinkais? Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
unia Paskelbta Balandžio 4, 2015 Pranešti Dalintis Paskelbta Balandžio 4, 2015 O kas patinka/nepatinka per tas pirmas moto valandas, domina, nes pats žiūrinėju. Iš kokių dar variantų rinkais? neturiu prie ko labai prikibti kadangi pats dirbu su juo ne darbininkai tai pirkau geresnes komplektacijos pilna amortizacija,vairavimo sistema sedyne xxl,padangos plačios,automatinis kondikas,led žibintai priekine pakaba su darbiniu ir t.t. kaina buvo 314,000 be pvm. rinkausi tarp fendt,john deer r serijos ir šitas, fendas kaina 20000e brangesnis nesu john deer fanas,o ir vadybininkas nesistengė parduot Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
saramedlov Paskelbta Balandžio 5, 2015 Pranešti Dalintis Paskelbta Balandžio 5, 2015 O dabar iš eilės: Zetor Forrtera HD 150 - 225 Lt +PVM (praktiskai pilna, su pakaba, be darbinio priekyje. Ta, kuri stovejo parodoje) NH 6 165 - 210 + PVM ( pilnas, su oru ir amortizacija, parodinis, kuris stovejo su drugeliu); JD 6150 M - 295 + PVM (negaliu pasakyti del dezes, bet oras ir kt. papai buvo); DF 6140 - 235 + PVM (parodinis, 6 kausu, pilnas, ne profi line"as, su pakaba priekyje); Valtra 173 T - 260 + PVM (atrodo buvo puse velnio komplektas, kadangi nedomino - tai tik isosre apziurejau. nieko gero); DF 6160/6180 TTV 305 +PVM ( jau smagus);\ Fend 516 Vario 415 + PVM (praktiskai pilni, parodoje nebuvo, bet vadybos zodziais tariant). MF net neziurejau. Silpna sirdis mano. Aurelijus Klm 1 Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
saramedlov Paskelbta Balandžio 5, 2015 Pranešti Dalintis Paskelbta Balandžio 5, 2015 O jei unia Jus nieko pries, tai noreciau jus aplankyti su namines litru ir aptarti df ttv . po velyku. Kai sveikata gris Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
dariius 30 Paskelbta Balandžio 6, 2015 Pranešti Dalintis Paskelbta Balandžio 6, 2015 Kai kuriu kaina kaip kosminio laivo cia dar sena valiuta Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
arunis Paskelbta Balandžio 6, 2015 Pranešti Dalintis Paskelbta Balandžio 6, 2015 cia vienas ukininkas papokstavo kai rinkosi tarp NH ir FENDT uz tuos pinigus nuperku nauja NH ir dar turiu 200 tukstanciu Lt remontui teisybes delei dar galiu pamineti jog pas ji uky dirba 2 fendt viena valtra trys nh ir dabar dar atvaziuoja case Miguelis 1 Nuoroda į komentarą Dalintis kituose puslapiuose More sharing options...
