dyras Paskelbta Gruodžio 10, 2009 Pranešti Paskelbta Gruodžio 10, 2009 Manau kad voras ir sėdėjo jame
Arminas666999 Paskelbta Gruodžio 13, 2009 Pranešti Paskelbta Gruodžio 13, 2009 Tokiu atveju fendtuose, kurie važiuoja 60 km/h ta sistema jau yra ar ne . Kas turit pasigirkite fendt 936 vario ABS tikrai yra nu bent tam su kuriuo dirbau
kapsukas Paskelbta Gruodžio 13, 2009 Pranešti Paskelbta Gruodžio 13, 2009 Tokiu atveju fendtuose, kurie važiuoja 60 km/h ta sistema jau yra ar ne . Kas turit pasigirkite fendt 936 vario ABS tikrai yra nu bent tam su kuriuo dirbau The new 800s are expected to make their first UK appearance in August 2010, by which time further options that are currently under development – a fully integrated tyre inflation system and anti-lock braking (ABS) – may also be available. Which brings us to the 936’s running gear. Headline news here is that the tractor is capable of 60km/hr, and with that lively maximum speed comes a lengthy list of associated spec sophistication – suspension, braking, steering. The independent front suspension unit is especially clever, in the main for its Fendt Stability Control (FSC) system that kicks in at 25km/hr+ to counter suspension movement as the tractor corners at speed. And even though our tractor made do without ABS, we had no complaint with its anchor power.
Arminas666999 Paskelbta Gruodžio 13, 2009 Pranešti Paskelbta Gruodžio 13, 2009 Tokiu atveju fendtuose, kurie važiuoja 60 km/h ta sistema jau yra ar ne . Kas turit pasigirkite fendt 936 vario ABS tikrai yra nu bent tam su kuriuo dirbau The new 800s are expected to make their first UK appearance in August 2010, by which time further options that are currently under development – a fully integrated tyre inflation system and anti-lock braking (ABS) – may also be available. Which brings us to the 936’s running gear. Headline news here is that the tractor is capable of 60km/hr, and with that lively maximum speed comes a lengthy list of associated spec sophistication – suspension, braking, steering. The independent front suspension unit is especially clever, in the main for its Fendt Stability Control (FSC) system that kicks in at 25km/hr+ to counter suspension movement as the tractor corners at speed. And even though our tractor made do without ABS, we had no complaint with its anchor power. kapsukas ka cia suveliai? nesioji zinutes is kitos temos
voras Paskelbta Gruodžio 14, 2009 Pranešti Paskelbta Gruodžio 14, 2009 reiks man savo patikrinti, dabar kaip tik slydu, nes pirma kazko ne nesusimasciau, bus maloni staigmena jei yra ir dar malonesne jei nera
voras Paskelbta Gruodžio 14, 2009 Pranešti Paskelbta Gruodžio 14, 2009 siandien visa diena kroviau grudus su pniaumatiniu transporteriu, per diena nesugebejau priekabos privaryti, pasirodo po elektriku linijos remonto fazes sukeistos ir jis sukasi i kita puse gaila tik kad 15 00 valanda aisku tepaliko zodziu tik rytoj
dyras Paskelbta Gruodžio 15, 2009 Pranešti Paskelbta Gruodžio 15, 2009 reiks man savo patikrinti, dabar kaip tik slydu, nes pirma kazko ne nesusimasciau, bus maloni staigmena jei yra ir dar malonesne jei nera Manau geriau nebandyk, žinant kad jis iš gamyklos važiavo 40 km/h, kaip ir neturėtų būti.
voras Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 zinant ??? visijie vienodi isvaziuoja is gamyklos, tik kompas riboja max greiti, taigi nera ten jokio abs, net ir tame kur kazkuris cia giriasi kad dirbo su tokiu kuris turi abs, klounas i tiek
drapox Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 zinant ???visijie vienodi isvaziuoja is gamyklos, tik kompas riboja max greiti, taigi nera ten jokio abs, net ir tame kur kazkuris cia giriasi kad dirbo su tokiu kuris turi abs, klounas i tiek Na negirdėjau ir aš, kad Fendt turėtų ABS. Nei 900 serijos aprašyme, nei gamyklinėj konfigūratoriaus komplektacijoj nesimato dar ABS. Nebent įdėtų į naująją 800 seriją.
Arminas666999 Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 zinant ???visijie vienodi isvaziuoja is gamyklos, tik kompas riboja max greiti, taigi nera ten jokio abs, net ir tame kur kazkuris cia giriasi kad dirbo su tokiu kuris turi abs, klounas i tiek gr nereik cia waryt sakau kaip yra zviru wariau ir sakau reik pamegint kaip stabdziai uzmigau iki dugno ir ratai neciuoze tai kas tada ten buwo?
voras Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 tai buvo nesuvalgytu pusryciu pasekme siaip traktoriaus svoris didelis ir stabdyti taip kad ciuoztu ratai as nesiryzciau, nebent ant ledo ir be priekabos
Arminas666999 Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 tai buvo nesuvalgytu pusryciu pasekme siaip traktoriaus svoris didelis ir stabdyti taip kad ciuoztu ratai as nesiryzciau, nebent ant ledo ir be priekabos nebent tavo pusryciai waziavau pasikabines gilumini purentuva
voras Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 po paskutino pasivazinejimo su giluminiu purentuvu apie stabdyma tokiu intensyvumu ne nedrisciau pagalvoti, labaijau daug gali kainuoti pasekmes
Arminas666999 Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 po paskutino pasivazinejimo su giluminiu purentuvu apie stabdyma tokiu intensyvumu ne nedrisciau pagalvoti, labaijau daug gali kainuoti pasekmes nelabai supratau kokios dar pasekmes gi ne i siena stabdziau
1mangustas Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 jauciu ne su savo fendu lekei
dyras Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 Vorai, tai arminas tavo fendtą suvarė tai išeina
drapox Paskelbta Gruodžio 21, 2009 Pranešti Paskelbta Gruodžio 21, 2009 po paskutino pasivazinejimo su giluminiu purentuvu apie stabdyma tokiu intensyvumu ne nedrisciau pagalvoti, labaijau daug gali kainuoti pasekmes nelabai supratau kokios dar pasekmes gi ne i siena stabdziau Fendt stabdžiai nėr tokie jautrūs, kad užkirstų labai staigiai, o tai ir kulvirstį gali padaryt jei ką... Bet tema tai apie Puma CVX. čia saviplaka, kad moderatoriai ne taip pyktų.
voras Paskelbta Gruodžio 22, 2009 Pranešti Paskelbta Gruodžio 22, 2009 shaunuolis drapox, varom ne i tema
Arminas666999 Paskelbta Gruodžio 22, 2009 Pranešti Paskelbta Gruodžio 22, 2009 Kaip visada voras ne į tema nepriimk uz rimta
voras Paskelbta Gruodžio 23, 2009 Pranešti Paskelbta Gruodžio 23, 2009 nu jo, tik va pradejau tai ne as apie abs tam tikros markes traktoriuje, as gal tik aiskumo ivedziau, o gavosi kad vel kaltas
Algis... Paskelbta Gruodžio 29, 2009 Pranešti Paskelbta Gruodžio 29, 2009 Stai kaip galima "svelnu zveriuka" panaudoti ir transporte
beleris Paskelbta Gruodžio 29, 2009 Pranešti Paskelbta Gruodžio 29, 2009 Stai kaip galima "svelnu zveriuka" panaudoti ir transporte Ot,velnias...ir kur as tuos milionus uzkisau...
ausrius Paskelbta Gruodžio 29, 2009 Pranešti Paskelbta Gruodžio 29, 2009 Neimk, Rimvydai i plaucius, o tai kai pradeda tokie kaip arminas lakstyti traktorius gave , tai ir 936 pradeda greiciu dezes byreti.
Arminas666999 Paskelbta Gruodžio 29, 2009 Pranešti Paskelbta Gruodžio 29, 2009 Neimk, Rimvydai i plaucius, o tai kai pradeda tokie kaip arminas lakstyti traktorius gave, tai ir 936 pradeda greiciu dezes byreti. Na dar ne viena deze nesubirejo jusu ziniai
